IFLY152
I installed a new Viofo A119 V3 in my 2012 Acura TL and hardwired it to the fuse box by the passeger's kick panel. The dashcam received power and worked fine, but the problem is that it constantly receives power and runs constantly. I want it to only have power when the engine is running or the car is in ACCessories Mode. I used an Add-a-Fuse kit to tap power from the ACC fuse socket (#16 in the pictures). The ACC receptacle had no power when the car is OFF and not in ACC mode, yet its fuse socket has power all the time (I checked with a voltmeter). Same thing when I tapped from the Power Window fuse socket (#11). The power window wouldn't operate when the engine is OFF and not in ACC mode, yet the Power Window fuse socket has power all the time. How is that possible?
I hardwired a Viofo A119 V2 in my 2007 Miata using the same technique by tapping into the ACC fuse socket and it works as desired (only when engine is running or in ACC mode).
I'd appreciate any help you can give me.
