Al Drake
With the introduction of more dash cams that are using the CPL(circular polarizing lens) it is important to learn as much as possible about this filter. In this video towards the end there is a list of which brands are recommended and which should be avoided and why. The reason I like the LUKAS LK-7900 ACE vs. the Finevu is the LUKAS uses a standard 37mm threaded CLP and allows one to purchase a quality lens and avoid vignetting
http://www.google.com/#hl=en&sclient=ps ... 20&bih=929
There are some CPL lens that are not true rotating polarizers and must be avoided as they can not be adjusted which is very important.
http://www.ebay.com/gds/Circular-vs-Lin ... 386/g.html
Another way of avoiding vignetting is to use a larger size filter(CPL) with a step up adaptor to make the lens overlap assuring there are no visible edges.
http://www.amazon.com/Adorama-Step-Up-A ... B0002GVX7Q
This is only an example and not a recommendation. The best option is to pay for the best CPL you can afford. Something that can last a lifetime if properly cared for. These quality filters do not degrade the quality of the video and will give amazing results.
Good luck and have fun.
Al.
Al.
