In that pic i think its just regular tape i have allso tried duct tape, as long as it isent too thick it should still work.
The things i have tried have not been install and forget, will have to be redone once in a while.
The card slot on the 9665GC isent optimal thats for sure, and if you are the type that trim the nails often then its even worse, i can only hope SG can make it a little better in future models.
Somthing like the SD / sim card holder on many phones would be stellar i think ( not that i have tried a phone like that, but i have seen pictures where the SD/sim card go into a little cradle you then slide into the phone ( on the side usioally )
In my Kingston card reader the micro SD card protrude 3 mm or so when its in there, but offcourse thats allso not a click lock slot.
You might allso be able to glue onto the card some thicker and stronger plastic, if i was to try that i would go to my old workplace and get one of those clear rip off plastich we used on the painting masks, its fairly stiff but still less than 0.5 mm i recon.
But as the other guys said dont get cyano glue near any lens while its still wet or curing, the stuff give off some nasty vapors. -
I left it for an hour or so to make sure the glue had set hard.
I will try to retrive my 9665GC on my next drive then i will do a little experimenting on my end too, somthing stiff would be best i recon in aiding insertion of the SD card. -
I have tried a piece of stiff plastic from an el cheapo spray bottle and I have also tried a piece of laminator plastic that was stiff enough for the job, the problem is the glue will not adhere to the SD Card .
What ever you do you will have to stay above the little noch on the side of the card, i think whats below that will be inside the metal part of the card socket so little or no room for anything there.
- as you say a little bit bigger notch or an upgrade to a proper SD Card would be the go. I haven't read up on why Street Guardian chose the micro sd card route.
For the time being I will stick with the baseball cap and key trick and bounce the idea off some mates and see whta they come up with.
