Constantinus
@Jeff_Vantrue
Hello,
Tl;dr: it works when I connect the LTE module to the E360's GPS mount, but not when I connect it to the E360 directly.
Is this a supported use case? I intend to install the E360 upside down on the dashboard. Everything works fine with its GPS mount, but the GPS mount is making the camera too tall. I was hoping to use the camera without the GPS mount, but still access it remotely.
When I bypass the GPS mount, then try to connect to the system via LTE, with the app, the app sometimes displays a connection error, sometimes just goes back to the previous screen.
I'm using the LT01 module's own cable between LT01-E360, and the supply is from a VP03(II) hardwire.
Is there support in the LT01 firmware for direct connection to the E360 directly, bypassing the E360's GPS mount?
Thank you.
Hello,
Thank you.
