I'm sure there are some pictures somewhere, but I suspect Viofo will have changed suppliers/brands a few times by now!
Super capacitors are pretty standard, they all have roughly the same voltage and temperature limits, it is really only the capacitance that changes, and you specify that when you buy it. If you are buying one then you need to make sure it will fit in the case, but it does not need to be exactly the same size or brand, or even capacity as the originals, just not lower capacity.
