Installing a Memory Card (Recommended: Vantrue U3 high-speed microSD card).
Please insert a memory card (memory card capacity: 32GB-512GB, card speed: U3/Classl0/A2), The dashcam has certain requirements on the card speed of the memory card. For reliable operation, we recommend using a VANTRUE SD card (sold separately).
Memory Card Installation: There is an icon indicating the insertion direction of the memory card. Please push the memory card into the card slot according to the direction indicated by this icon, until a "click" sound is heard in the card slot, indicating that the memory card is inserted properly.
Reminder
1. The microSD card should be formatted once a month to maximize the lifetime of the memory card.
2. Please do not take the card out when the camera is recording in case the important video files missing.
4. Before formatting the memory card, please check the event video folder in the SD card to see if there are any videos that need to be saved separately, so as not to delete important videos by mistake.
We recommend formatting the dashcam regularly to ensure the best performance of the dashcam. But in case you forget to do so, we add “Format Reminder Setup” in the settings:
Menu> System Setup> Format Reminder Setup> 15 Days/ 1 Month/ Off
When time is up, the format info pops up to remind you to format the dashcam.
Reminder
3. Please do not use bad cards or low-speed cards on the dash cam, as it is easy to stop or lose the recording due to the failure of a memory card.
