0806 doesn't seem to get hot or even warm enough to need one!So no difference in hardware between 0805 and 0806. Is the overheating issue resolved once and for all in the 0805 compared to the 0803?
Will 0806 have the capability of using capacitor?
I've not noticed it getting hot when it's not running, even when in parking mode it appears to stay at room temperature as far as I can measurecapacitor has nothing to do with how hot the camera is when running
I've not noticed it getting hot when it's not running, even when in parking mode it appears to stay at room temperature as far as I can measure![]()
The battery isn't being charged in "parking mode" though so I don't think it is a concern, other than that it will go flat after a while.That's good to hear, the battery is the main concern though with parking mode
It uses battery power once you turn the main power off, but probably best to turn it off completely if you are leaving the car for a week or two as lithium batteries don't like being run completely flat, at least it doesn't flatten your car batteryParking mode requires permanent power, are you talking about just running off battery until it runs flat?
For the video quality, 806 is almost same as 805 because use same solution.Thanks for the video. I'm happy to see improved night time video quality. By the sound of it, 0806 will be a very attractive package if it can improve and have better design. I definitely will keep an eye out for it when it's released.
