Mini 0806 - Hardwire issue
steve11
SG9665GC, Mini 0806 running off a Lukas 290 hardwire
Hello,
(I have posted this same question on the Lukas board, apologies for the double post I just need the largest exposure I can get)
I need assistance with connecting the Lukas LK-290 harwire kit to run my Mini 0806 dashcam.
I believe I've followed the correct steps but the Lukas unit constantly blinks red and the Camera has constant power, even when I've turned the Lukas unit off and also turned off my car ignition.
I will describe me steps, hopefully someone can pin piont my error, I have a Ford Mondeo MK4 Turbo Diesel.
The unit is set to 12 volt with the cutoff at 12.4V.
1) I have attached the Yellow Lukas wire to the fuse that runs the headlights (this is my always on power).
2) I have attached the Red Lukas wire to the fuse that runs my windscreen wipers (this is my Acc power).
3) I used fuse double adaptors for the connections, both the Headlights and Wipers use a Blue 15amp fuse, I used a Red 10amp fuse for the Lukas unit.
4) I attached the Black Lukas wire to a bolt (touching metal) next to the fuse box (this is my earth).
Not sure what to do now.
Thanks in advance.
