Hi estore009, I have a 128Gb Samsung Evo Plus but I'm still getting repeated "SD card low speed" notifications. I've reformatted a few times but it comes back after a day or so. Any further tips?
I'm running 04.190401.V0 which from memory is the low bit rate continuous recording option.Are you on the latest firmware?
Thanks estore009. So I need to decide between the low bite rate continuous recording, or the auto reset beta? I've been relatively happy with the performance of the low bit rate, other than the low speed errors. I might check when the announcement is being made if it's still actually recording. If it is I might just turn the announcements off!Have a look at this post...Feature request: Auto reset after 5 seconds of 'SD card slow speed'
Hopefully soon! https://drive.google.com/file/d/1xc2juUts5TXxg9dPWSufPqaLY0A5wT-R/view?usp=sharing Please load this beta firmware( BSSC04.2020622.V1), and report here if any questions!dashcamtalk.com
Same issue for me. Cards I’ve tried are perfect but the camera still gives the low speed error. Now I have to try and return the camera. Might just get a refund and buy a different camera in case it happens againThanks estore009. So I need to decide between the low bite rate continuous recording, or the auto reset beta? I've been relatively happy with the performance of the low bit rate, other than the low speed errors. I might check when the announcement is being made if it's still actually recording. If it is I might just turn the announcements off!
Yes you can return it back for the refund or replacement within 1-year warranty!Might just get a refund and buy a different camera in case it happens again
Do I return it to you?Yes you can return it back for the refund or replacement within 1-year warranty!
