Missing Video Clip Files
2Stan
Big Horn, Wyoming
Mini 0807 - four - 1 on each side, 1 front, 1 rear of RV
I have set my Mini 0807 to record 5Min segment clips but from time to time the file numbers skip and I get no video from the file numbers that are skipped. For example video file 1081m skipped for 30 minutes to file 1088m when there should have been 7 continuous files generated . Could this be from using too fast of a SD card? I am using Class 10 instead of slower Class 6 cards.
photo.php
What kind of card are you currently using? Just wondering which DVR firmware you are running? The more detailed information you can provide, the better.
Using a SanDisk Ultra Plus 32GB and firmware FW20160713 V1.0 - am using the basic default settings except that I'm using English, MPH, Flicker 60Hz & Recycle 5Min - I believe my sensor is the 1080 since 1920 x 1080 shows up as a resolution choice
