Hi Iincent,
Thank you for your quick reply to my Mobuis question. My camera still defaults to 720P on autostart up. I do not know what I am doing wrong? All of my other sys.config changes work fine: date/time,autostart,movie loop and movie flip.
What am I doing wrong? Thanks for all your help.
See all my current sys.config settings below:
Date time=[2013/08/30-05:14:12];date time setting,format yyyy/mm/dd hh:mm:ss
Video Mode 1 resolution=[1];Movie resolution setting,1:1080p,0:720p
Video Mode 1 Frame Rate=[2];Movie frame rate setting,1:60fps (only for 720p), 2:30fps
Video Mode 2 resolution=[1];Movie resolution setting,0:1080p,1:720p
Video Mode 2 Frame Rate=[1];Movie frame rate setting,1:60fps (only for 720p),2:30fps
Photo Mode Capture Size=[0];set photo size,0:2304x1536,1:1920x1080,2:1280x720
Set Time Lapse Shooting=[0],0
ff,1:0.25s,2:0.5s,3:1s,4:2s,5:5s,6:10s,7:30s,8:60s
Movie cycle time=[2];movie cycle time,0:3 minutes,1:5 minutes,2:10 minutes,3:15 minutes,4:max to 4G byte,
Movie Loop Recording=[1];set loop recording on or off,0
ff,1
n,
Time stamp=[1];set date/time stamp on or off,0
ff,1
n,
Movie sound=[1];set movie sound,0:mute,1
n,
Movie Flip=[1];set movie rotate,0
ff,1
n,
Movie quality=[1];set movie quality,set movie data rate,0:Super,1:Standard,2:Low,
Movie high dynamic range=[0];set movie high dynamic range,0
ff,1
n,
Power on=[1];set system power on time,0:delay,1:fast
Power off=[1];set system auto power off time when system pending,0
ff,1:30 seconds,2:1 minutes,3:2 minutes,
Auto Record=[1];set connect or disconnect with power to start or stop video recording automatically,,0
ff,1
n,
LED=[1];set LED flicker when recording,0
ff,1
n,
Charge from USB Host=[0]; when connecting with USB host, charge camera or not,0
n,1
ff
TV out=[0];set Tv out,0:NTSC,1
AL,
TV Display Ratio=[0];set display ratio,0:4*3,1:16*9
{TLCAM MOV:TLCAM Mobius ActionCam 2013/07/30 v0.39}
{LDTLCAM,v003}
