I don't know if this is the correct place to post this, but I thought what the heck. Give it a try.
I would like to see the Mobius be able to easily support more of the high capacity memory cards (128GB and larger). I don't know if that's something that would have to be updated in the bootloader, firmware or some other part of the device. But with recording at such high resolutions, a large capacity memory card is basically required (in my opinion).
Alternately, but not realistic, they could swap out the Micro SDHC card slot with a USB 3.0 slot that would allow recording directly to an external USB HDD (it could be powered through the Mobius, or an external source). Could you imagine having a 2TB external HDD hooked up to your Mobius? It would record for DAYS on the highest resolution settings!!! That would make it the most desireable dashboard cam for vehicles ever.
You could just unhook your external HDD and connect it to your PC to copy/transfer files from it. Or just switch it out with a different external HDD. Depending on your budget.
