russ331
- Aug 10, 2013
- Kingston on Thames
- United Kingdom
- Mobius B (x2) & A119
Just now posted at http://www.rcgroups.com/forums/showthread.php?t=1904559
This FW v0.53 update is available for D/L in Post #3.
ALERT! You MUST D/L the latest GUI to work properly with this new FW since it has added some new functions, which include:
- 60Hz and 50Hz settings to eliminate flicker with some lighting caused by AC power line frequency.
- Global 180 deg. image rotation has been replaced with individual toggles for both video modes and photo mode.
- Lens A and Lens B auto WB correction options for Standard (Lens A) and Wide Angle (Lens B) lenses.
- Narrow AOV mode added to 1080p mode to capture 1920x1080 native pixels from the larger CMOS array. Original mode (now called Large) has been and still is a scaled down image that captures the full AOV of the larger 3:2 aspect ratio CMOS in a 16x9 aspect ratio image.
- Auto recording can now be toggled to start when power button is press and/or when external USB power is connected (with no active data lines).
- Auto recording started with external USB power can now be toggled to stop/save immediately, continue for 10 seconds, or continue until internal battery power runs out.
- Battery Charge Indicator blinks the rear red LED only from 1 to 3 times when camera first boots to show approximate state of charge (1=low and 3=high).
NOTE: Before anyone complains about their recording time based on the number of LED blinks, please read this post and those linked in it so you know the limitations of this method of determining battery state of charge.
