Hello,
I am on my second mobius camera. Both cameras have suffered the same issue within 3 weeks of use. I am hoping that someone out there knows whats up. I don't want to give up on the mobius camera, as its exactly what I need minus this issue.
The issue:
The camera via mini usb cable is no longer picked up by any pc that it is plugged into. The date has reverted to default, and cannot be updated.
I use my mobius as a dashcam, which is mounted on a suction cup mounting system, and connected via miniusb to an anker 13000mah powerbank, I use this while I am parked at work, (someone whacked my car for 5500 bucks of damage and got away with it), and for driving as I learned, one can never be too careful.
I feel like its a hardware issue with the mobius, but I'm not positive. The sucker gets pretty hot, and having a cable hang out of it, can't be a good thing.
I've tried multiple cables, and multiple usb ports, and multiple computers, and multiple programs to clean out usb drivers. I run windows 7 primarily, but I have several computers running other os's.
The first time this happened, I returned it, and the new one worked perfect. After 2 weeks in the car, not so much.
When it was new, it was picked up at every usb port, with every cable that I tried. It could be used as a webcam or I could browse the drive for the video files.
I upgraded it with a capacitor, and I have two class 10 64gb sandisk microsdxc cards that I can swap if needed.
I updated the firmware to the newest 2.33, and all of this worked perfect until recently. It still receives power from the miniusb cable, and since I set it to record when external power is connected, it will record in the car. The buttons are still responsive on the camera, as far as I can tell. Power will turn it off and on, and mode will swap, and record will record. The problem is connecting to computers.
When I mounted the capacitor, I used the double sided tape that was already in the camera from the battery and mounted it over the usb port. Maybe it gets hotter then the battery and damaged the usb?
Maybe the bumps in the road, caused jiggling of the cable and damaged the port? I had planned on running an up angle miniusb into the liner of my car around to my glove box, so there wouldn't be pressure/pulling, but hadn't gotten to that point yet.
The weather has been cold, where I am ~35-45 degrees f. So its not like its in a completely hostile environment.
I run the camera around 6.5 hrs at a time.
I'm at a loss here as to what's happening. All I can think of is, is hardware damage from overheating. I don't want to just replace this one and have the same thing happen. If I am doing something wrong, knowing that would be a big help. I've invested a bunch of time, and a bit of money into this project. I would hate to have to find another camera that can be used for my car and out about in the world.
Thanks for any insight
The issue:
