liveinxs
- Oct 1, 2014
- Bridgewater, NJ
- Mobius ActionCam, Front, Rear and both Sides
I see a lot of people are having issues where the Mobius fails to come on, when the vehicle is started..
I think I might have the solution, I have purchased a 12v switch, which can be set to turn on and off, in many different ways..
I have mine set, so that when it senses a 12v signal, it turns on, but then goes into a setup, whereas it repeats the process, over and over again, it is set to cycle the power on and off, every 1 second..
I have noticed, that when anyone of my 4 mobius cams, fails to start, all I have to do is unplug it at the mini USB, and plug it right back in, and then it turns on..
So my thought, is that if we can repeatedly send a on and off signal to the cam, it should remedy, any issue of it not starting..
Only downside I feel might happen is, is if the cam shuts down, short of 1 second, and even my cams, all contains super capacitors, I don't believe that will happen, I believe, it will turn back on in time to prevent a shutdown..
Only issue so far, is getting a warm day to install the switch and test it..
Any input on this is welcome, also, what has been the shutdown time of the mobius with a super capacitors installed...
I have enclosed a short video of the switch in action...
http://s259.photobucket.com/user/inxs996/media/20150224_123054.mp4.html
