New to dash cams and Mobius.
I have a 2015 Mazda 3 GS, which as 2 USB ports and a 12V port next to each other. When I bought Mobius, I assumed that I could just plug it into one of the USB ports and enable auto-record with loop recording on. However, it turns out that the car recognizes Mobius as a storage device and it appears on my entertainment system.
1. Does this mean that my only option is to use the supplied 12V adapter that powers Mobius as a separate device?
2. If Mobius is powered by a 12V adapter, will it turn off by itself if I turn the car off or will it continue recording forever until I unplug the USB from the 12V adapter?
3. In case I will ever want to add a rear window dash cam (redundant?) should I get a 12V adapter with two USB ports?
Thank you.
Thank you.
