MedicalFlyer
- Feb 10, 2015
- United Kingdom
- Mobius C Lens, Mini 0906, SG9663DC Pro, A229 Plus
Hi All,
Well my plan for bulk buying some Mini 0806's went south due to the others involved changing their minds. So now I'm swaying back towards a semi-permanent discreet solution.
Having read around on the Mobius and the new C lens here's what I'm planning.
Front:
Mobius unit velcro'd to the roof lining around the interior light/sunvisor
Lens extension lead trailing down to the rear view mirror
Lens either mounted on the mirror or it's mount (again with some way of detaching when needed)
Power eventually supplied from a hardwire job in the fusebox which is at the bottom of the a-pillar.
All in around £60-70 going by banggood's prices.
Rear:
I was thinking along the same lines as above but then I was thinking how could I get to the buttons on the unit to lock a file when needed (such as the Royal Mail truck that though 4 inches off my bumper was safe on the motorway last night)
Would it be possible (or even feasible) to connect multiple extension leads together so as I could bring the main unit to the front of the car?
I have an estate so it would take a fair few extensions (approx. 3 metres)
Hiding that cable run would be the tricky bit - maybe a false headlining velcro'd over it down the centre of the car.
Or would you suggest a different unit altogether (around £100 or less).
Any thoughts on either of these set ups would be greatly appreciated.
Front:
Rear:
