MedicalFlyer
- Feb 10, 2015
- United Kingdom
- Mobius C Lens, Mini 0906, SG9663DC Pro, A229 Plus
Finally got round to fitting my 0906 in my new car yesterday and so far I'm not as happy as I was with the mobius in my previous car using a lens extension.
I have a 2008 Kia Cee'd and got the front camera mounted on the windscreen to the left of the rear view mirror (I'm in the UK).
As such the body is rotated so the sd card is at the top and the USB connections are at the bottom.
The camera itself is fine where it is even if its a little noticeable from outside. It's handy being able to see the status lights at a glance (screen off as it should be per UK law).
I had a quick mock up of where to mount the rear camera and this is where I start to dislike the 0906 setup. Aside rom working out how I will route the cable to the front, once it gets there it will have to plug in to the bottom of the camera unit and will look untidy and maybe draw more attention from outside.
It's a shame the rear cam doesn't connect to the mount as it would be a lot tidier.
Ill try and get some pictures later but at the moment I'm just using the front cam to see how it compares to the mobius. I may not fit the rear until I can find a neater twin system (maybe the dr02-d might be tidier).
If anyone has any suggestions for a tidier install I'd be grateful. Maybe I can install it the other way around behind the mirror more.
