richardtopsoejensen
Hi everyone.
I recently bought a GS5000 which I think is very very good.
Not only is the sound good, but you can also trim the automatic light adjustment, so the recordings can be brighter or darker depending on you preferences. This is especially good for night recordings where it is dark outside.
Anyhow ... I bought the camera, but when I played back the recordings with the software that came with the camera it said: "'43.7327. is not a valid floating point or "the movie gps data error".
I expected that there was something wrong with the camera, but discovered that it was the software that did'nt work.
By downloading these two files, the camera worked perfectly (the first is a viewer and the second a converter):
http://translate.google.com/translate?s ... arod.ru%2F
http://www.codecguide.com/download_k-li ... _basic.htm
Hope that helps some of you that encounter the same problems I did.
KR The Dane.
PS! This one is even better : http://datakam.ru/item.php?cat=item&id=28
KR The Dane.
