My first 0806 problem
For those of you having this problem, could you post your memory card brand, model, and size?
I'm also having this problem where the 806 makes a noise (DING DING DING) before stopping recording then 30seconds + will start recording again 🙁
If it makes a loud noise when it stops then it is usually a card fault, give it a test with h2testw.exe. If I remember correctly yours gets a lot of use since you leave it recording when parked, I wouldn't be surprised if you have worn the card out if it is reasonably cheap card.
http://www.heise.de/download/h2testw.html
It also stops if I stop the car, wait for 5 minutes and then start again.
It's very frustrating, and I think I had better go back to the dusty Mobius.
I use a decent Sandisk (checked and swapped for another and formatted in the camera) and the supplied 12V cig-lighter plug and cable.
There have been a few people that have had that problem and solved it by fitting a hardwire kit, it seems that some of the cig-lighter adaptors create voltages that the camera doesn't like when the battery voltage drops while starting the engine.
Nigel, I had not heard this before. How can you identify cigarette lighter adapters that may be suspect?
I only format the card in the camera so I know that is not the source of the problem, only the temporary solution until it eventually happens again.
If it is a 32GB card then I would format it in your computer, I think there is a bug in the camera formatting of 32GB cards. Might be worth trying a computer format anyway.
There have been a few battery problems, but they normally fail in the first week or two. They can be replaced fairly cheaply but I guess you are better off returning it, since the battery is not user replaceable without DIY it should have a 1 year warrantee.
No idea, don't know how many types there are, but it also depends on the car, it normally is only a problem if the battery is fully charged - ie recently used. Maybe "normally" is the wrong word there since I can only remember a few reports of this.
