This is my first post (been lurker for very long time).
This post is based on experience of the dash cameras I had or came across.
The cameras I have/had/came across are:
Blackvue DR400G II (too much compression, really crappy auto exposure)
Navman/Mio MiVue 388 (piece of crap to be honest, no positives I can think of)
Mini0806 x4 (stability issues, wire issue, recently released and already obsolete)
Mini0805 x2 (old firmware, a bit too much compression)
G1W (a bit too cheaply made, image quality so so, feels like plastic toy and crappy mount)
So based on the cameras above here is what I would like to buy (I don't think this product exists, surprise me )
I simply fed up with crappiness of current offerings on the market.
- Resolution: at least 1080p @ 30fps (would love to have 4k or 1080p @ 60fps)
- Compression: at least H264 High profile, with ability to select bitrate and I-frame frequency (would love HEVC/H265)
- No reliance on internal battery (separate internal feed from constant 12V/Batt. supply for memory and shutdown). Similar to what car stereos do.
- Separate recorder from camera. This way camera becomes a small discreet unit. Recorder having at least two full HD (or UHD) inputs.
- Would love to have SSD instead of MicroSD cards (since recorder is separate, it is possible to make it physically larger). Or at least option to have CF. (MicroSD cards are very slow).
- CPL (to remove glare) and gradient filter (to darken the sky).
- GPS logging in an open format.
- Option of different camera lens (ie 2.8mm or 4mm) and resolution.
- Price bracket between $300US (single camera) - $500US (dual camera).
- Thermal management becomes much easier (ie: case is heat sink)
- Recording media options (CF or SSD)
- Security: someone breaks into the car steals the cameras, they will most likely miss the hidden recorder with recording of said break in.
- Fire safety: no more Lithium battery baking in the sun.
- One recorder multiple cameras.
- Cameras are much smaller (less obvious).
- Better camera placement due to smaller cameras (less obstruction and less glare).
- Due to size can run full blown OS (linux) with many more features.
- Having GSM card option can double as GPS tracker.
