HonestReview
- Feb 9, 2019
- Sweden
Reviewed Camera: myGEKOgear Orbit 950 Product Description: https://www.mygekogear.com/orbit-950-new/
vs.
Viofo A129 Duo - https://www.viofo.com/en/home/79-a1...wi-fi-full-hd-front-and-rear-dash-camera.html
![1595810679799.png 1595810679799.png](https://dashcamtalk.com/forum/data/attachments/52/52575-4e697cc4bd28eac1f65859d3e87bc405.jpg?hash=Tml8xL0o6s)
I received a Promotional myGekogear Orbit 950 and have been product testing the device for the past month. Before posting a review, I wanted to have comparative videos from my "go to device" the Viofo A129 Duo and the myGekogear Orbit 950 in various lighting conditions. Of note, I was not sent a hardwire kit so while my Viofo A129 Duo is hardwired, I was unable to test the parking feature on the myGekogear Orbit 950. Therefore, I am unable to comment about whether parking mode works as described and under what conditions.
Resolution and Image Sensor:
Both the Viofo A 129 Duo and myGekogear Orbit 950 were reliable when recording and I didn't notice any missing footage on any test runs and routine driving. Both Cameras offer a native 1080P HD Resolution.
myGekogear Orbit 950 image sensor: GC 2053 + 2053 CMOS
Viofo A129 Duo image sensor: Sony Starvis Image Sensor (Same for Rear Camera)
Mount:
The mount on the myGekogear Orbit 950 and Viofo are adhered direct to the windshield. I will say the mount on the myGekogear Orbit 950 does concern me. The camera can be pulled down, if gripping wrong, when trying to adjust settings. Meaning the mount isn't nearly as conducive as one that sits flush against the windshield.
One Note:
Viofo A129 Duo utilizes a Super Capacitor - The capacitor power supply has a wider temperature range and longer life span than cameras that use batteries, giving reliable operation in the heat of Australian summers and frozen Alaskan winters.
myGEKOgear Orbit 950 - utilizes a 240mAh Li-ion battery embedded . Li-on batteries do degrade over time and may not perform as well in inclement conditions (extreme hot and cold) over extended periods of use. Future suggestion may be for myGEKOgear to utilize Super Capacitors as they have a longer shelf life and reliability over extended use.
Unboxing Photos:
You will notice that the 3M pad and the Rear Camera for the myGEKOgear were larger than my defrost lines. You will either need to put the camera above the defrost lines or trim down the pad. Never place 3M adhesive over the defrost lines.
The camera comes with a stock 16GB MicroSD card. For my test, I utilized a Sandisk High Endurance 128GB card (Not Included).
Video Review:
The myGEKOgear Orbit 950 is a very capable camera. The video quality is excellent, albeit may benefit from some color adjustments. Daytime footage is overly saturated where the "greens" on the leaves are very bright. The overall daytime footage compared to the Viofo A129 Duo was on par with a mid level camera. Images were very clear.
Dawn and Night Video: myGEKOgear Orbit 950
The light sensor on the myGEKOgear Orbit 950 is superior to the Viofo A129 Duo. Although, the A129 Duo opts for a darker, more clearer, image. the myGEKOgear Orbit 950 easily picks up more surrounding scenery in low light conditions. However, in doing so, you do get a "warp speed" and/or blurred effect. Still, you will be able to see greater detail and more imagery. So if there happened to be an accident at night, the Viofo wouldn't necessarily caption the action, where as the myGEKOgear Orbit 950 offers a better peripheral view.
myGEKOgear Orbit 950 Android App
The app is user friendly and intuitive. I had no problems pulling off videos from the local Wifi connection.
vs.
Mount:
One Note:
Unboxing Photos:
Video Review:
