NanoQ0903 - does not overwrite old recordings
Marek77
Usa
Burundi
magagods
After the card was full, the camera stopped overwriting old recordings. Don't know how to repair it?
Some cameras have a setting for this, though i would think it would be set to overwriting when full as default.
Could also be your memory card is broken and in read only mode, this mean you can only copy filed from it but not write anything to the card.
But the camera writes files to the card until it is full. I'll try to change the card and see. Thank you
Okay if it can record after you have formatted it in camera or on PC, then it should be fine, then it is probably a setting.
A dashcam overwriting old footage is sort of the primary feature of a dashcam, along with starting and stopping to record automatic with the key of your car.
