I got the Mini 0806 for our upcoming road trip, but need some help with setting it up. I'm trying to achieve the following. Does anyone know how I should set my dashcam? I've went they the manual several times, but still clueless.
1. Continuous recording. I set my dashcam to the unlimited (4gb max), but once the recording reach 4gb, it stops recording and does not start recording on a new clip unless I manually press record. I'm ok if it needs to be segmented, but I prefer keeping in largest segments possible. If set to 1 min recording, it automatically start a new clip after 1 minute and continuously recording without interruption in 1 min clips. When set to the max (4gb) clip, it stops when 4gb clip is reached and does not start recording a new clip.
2. How do I config it so that it does not erase (overwrite) the oldest clip when the card is full?
3. How do I know when both micro-sd are full so I can swap it out? I have 4 x 128gb cards that I'm going to use for the dashcam. I will transfer the clips out at night to a laptop. I can get more cards if needed. I just need to make sure it does not overwrite the oldest clip when the storage capacity is reach.
4. How do I set it so that the dashcam does not power on each time the car is started? I want to manually power on the dashcam. Every time when the dashcam lose power (ex. when the car is turned off), it turns off and then back on when the is started.
5. Night recording. Do I set anything if I want to record at night time or is it automatic?
6. What video resolution is recommended? I don't want to compromise the quality of the video, but setting to highest resolution will use up the card space too fast. I was better than decent quality since it would be the primary recorder to capture the road trip.
