I recently installed a WM1 hooked up using the hardware kit (HK4 IIRC). Firmware is up to date.
I do NOT need it to record when parked, it's in a locked garage 90% of the time so I've turned OFF parking mode in the app. No shock or motion just plain OFF.
When I stop the car and turn it off, the camera keeps on recording, no change, no voice saying something changed, just hours of the underside of my car cover....
I've double checked the wiring, red to constant battery and yellow to a ignition switched source, black to ground. Since it's an older car I didn't piggyback off existing fuses, just added inline fuses to both power and ignition sources
I triple checked the accessory source to make sure it's off when the car is turned off and then even pulled the fuse on that wire. Camera keeps recording, solid red light
Double - triple checked the app settings, parking mode is off
Hopefully just missing something simple. Any help would be appreciated
