Newbie
Labradorneil
Please help - I have just received via a Mini 0806s together with apparently the correct hardwire kit.
There were no instructions with the hardwire kit on fitting and the supplier had no idea how the wires should be attached to the fuse box.
My main problem is I have three wires - black (I'm ok with) Red and yellow. Could you please advise on how and where to connect these wires.
Thanks for the reply - not sure it helps though. The red wire appears to be fused.
Please reply in simple and comprehensive terms, as I have little understanding of the subject.
The fused wire is normally BATT (constant).
likely, either way both should be fused
I agree in theory but as most folks use fuse taps with such hardwire kits, are these in-line fuses really needed?
I'd contemplated chopping off the in-line fuse off the Vico PP but didn't do it.
