vr6baz
- Jul 7, 2023
- Gosport
- United Kingdom
- Nextbase 322GW
Advise please on a nextbase 322gw + rear window cam, my devises are 4-5 year old and the battery in the 322gw not holding a charge (charged out of car but will loose charge after 4 minutes or less).
322gw working okay in car and records to Sd card, do not you use parking mode. Rear window cam not showing on 322gw.
I've swaped out a friend working rear cam with no difference.
Will replace battery when Nextbase UK have battery back in stock.
My question is should the rear window cam still function, ie show on the 322gw screen and record with the depleated 322gw cam battery.
Note 322GW hard wired into car and shows charging in info screen when running.
Regards
Regards
