NextBase 422GW Battery Number / Spec?
CalFixedIt
West Coast
NextBase 522GW, 422GW, 322GW
Hello all, new user here.
Does anyone know the battery dimensions / spec for the NextBase 422GW? - I'm guessing PL353030H or something close to that...
I'm guessing the 422GW and 322GW share the same battery spec, which is apparently different from the 522GW / 622GW.
I own a 322GW, 422GW, and a 522GW. The 422GW needs a new battery (only lasts 1.5 minutes under NextBase test procedure) and it definitely uses a smaller battery than my 522GW, but I don't see a number on it to identify the spec.
The 522GW / 622GW battery spec is a PL353040H LiPo 3 wire with thermistor - if I remember correctly that means 3.5mm x 30mm x 40mm - and it looks to me to be too big to fit in the battery space of the 422GW, and therefore I'm guessing too big for the 322GW also, as the 322GW and 422GW appear to share the same smaller enclosure, where the 522GW / 622GW have the bigger enclosure and bigger battery.
Many thanks - Cal
Many thanks - Cal
I found the 422GW battery spec - the original is a PL333133H with NTC thermistor - 3.3mm x 31mm x 33mm 3.7v 280mAH 1.04Ah
The commonly found China sourced 333133's are 320mAh
…and I noticed considerable internal differences between the 322GW and 422GW so wouldn't assume they use the same battery…
