No ACC+
fsa259
I have been informed that my Octavia VRS, because it uses CANBUS, doesn't have an ACC+ position...so where do I plug in the second wire of the PMP?
I have read other threads here, but still am confused. If I put both in permanent live, it will discharge the battery, I understand that. So instead of ACC+, I use ignition+?
To test the blank fuse slots, I just pop in a spare spade fuse and test the voltage going through it with a multimeter? I intend to use spare slots instead of piggyback.
Take out a multimeter,
find a fuse that does not have power (reads 0V) when the car is off but has power when the car is running, use it.
Thanks, Kandrey!
And other wire is for a fuse that does have power when car is off?
ACC+ wire is for when the fuse is powered only when the car is on.
BATT wire is for when the fuse is powered all the time.
