Well, apparently it did not get bricked, as I was able to get it to power on through the module. I was also able to upgrade it with the new firmware for the front cam, since I have it setting on the work bench, I did not load the firmware for the rear channel (cam) until I place it back in the car. But, (there is usually a but don’t ya know….). While setting on the bench, in a corner looking at the ground, with no motion anywhere, it goes from “one channel recording” to “parking mode” for whatever reason! this will occur at approximately every ten minutes. So, I am pleased it’s finally going into parking mode but now I am dealing with a repetitive cycle,
I do have a replacement coming, but, I wanted to try and give this thing a good go at it and figure out a plausible explanation, although, I probably won’t get it figured out before the replacement arrives here on Monday. I had a A139 Pro that worked great but I opted for the A229 Pro for its voice recognition. I also have a replacement battery pack coming (Cellink power 8) battery pack coming, I think that’s the name of it! Anyway, I need to end the story! This 70 year old man needs to stop playing with installs in vehicles, I’m also a amateur radio operator, I don’t stretch and bend like I used to……
