Make sure, when you saved your changes using JNovatekDec, that your file size does not increase.Thanks for responding. I tried doing that and it flashes then won't work. I have to reflash the original firmware to get it to work again. Anything I can do to provide you more info fortroubleshooting?
NTKFWinfo - python script for work with Novatek firmware files
Copyright © 2022 Dex9999(4pda.to) aka Dex aka EgorKin(GitHub, etc.)
NVTPACK_FW_HDR2 found
NVTPACK_FW_HDR2_VERSION found
Found 4 partitions
Firmware file ORIG_CRC:0x254F CALC_CRC:0x254F
-------------------------------------------------- PARTITIONS INFO ---------------------------------------------------
| ID START_OFFSET END_OFFSET SIZE ORIG_CRC CALC_CRC TYPE |
1 0x000000B0 - 0x00000AFC 2636 0x26EC 0x26EC MODELEXT INFO, Chip:NT96675, Build:20220729
2 0x00000AFC - 0x0024C5C0 2407108 0xE5C6 0xE5C6 BCL1, LZMA 9055844 packed to 2407092 bytes
3 0x0024C5C0 - 0x0028F23C 273532 0x2061 0x2061 uboot
4 0x0028F23C - 0x002EF054 392728 0xF551 0xF551 BCL1, LZMA 1084300 packed to 392712 bytes
Show full FW info, allow extract/replace/uncompress/compress partitions, fixCRC
Found 4 partitions
Firmware file size 3 076 180 bytes
(base) PS C:\Users\User\Documents\MotorDV\firmware> python .\NTKFWinfo.py -i .\db-1\FW96675A.bin -c 2
Found 4 partitions
Compress .\db-1\FW96675A.bin-uncomp_partitionID2 to partition ID 2 at 0x00000AFC
'rm' is not recognized as an internal or external command,
operable program or batch file.
Partition ID 2 - CRC fixed
Firmware file size 3 028 404 bytes
Firmware file ORIG_CRC:0x254F CALC_CRC:0x1640, CRC fixed
Found 4 partitions
Firmware file ORIG_CRC:0x1640 CALC_CRC:0x1640
2 0x00000AFC - 0x00240B1E 2359330 0xE0F0 0xE0F0 BCL1, LZMA 9055844 packed to 2359314 bytes
3 0x00240B20 - 0x0028379C 273532 0x2061 0x2061 uboot
4 0x0028379C - 0x002E35B4 392728 0xF551 0xF551 BCL1, LZMA 1084300 packed to 392712 bytes
Just tried flashing it. Lights blink then stop blinking, then I wait 5 minutes and turn it on, I get blink a few blinks then another blink or two and it stops and does nothing.That shouldn’t be a problem, no.
Compression can vary in file size and the tool automatically sets the size and checksum headers correctly.
Odd... can you send me the firmware file you modified?Just tried flashing it. Lights blink then stop blinking, then I wait 5 minutes and turn it on, I get blink a few blinks then another blink or two and it stops and does nothing.
Sure. Thanks again for taking a look at this.Odd... can you send me the firmware file you modified?
I can't think of anything that would make it fail, JNovatek not updating the checksum properly maybe or NTKFWInfo not packing it/updating headers properly?
I've tested NTKFWInfo on my NT96670 and it works fine, making changes using JNovatek I have not tested yet.
Sadly the only way you could check why its failing is by soldering a few wires to the UART port (if there is even a connection on the board) and connecting to it using a terminal program.
Does it matter that the DB-1 has two cameras?Well, I didn't find anything wrong with the modified version.
The checksums are in OK, so is the file size.
I even tried to use JNovatek to change the bitrate for my dashcam, and it booted up and worked.
I tried modifying the same bitrate you changed and the files are identical.
What I recommend you trying is, when you update the camera, once it stops blinking:
Stick the SD-card back into your computer and delete the firmware file off of it.
Then try to normally boot your camera.
What I think is happening is the following:
1. UBOOT starts the update procedure once it finds "FW96675A.bin" on the SD root.
2. Update process completes.
3. UBOOT tries to delete the update file, which is probably under a different name (probably), or something else which fails.
4. The camera shuts off.
5. The camera boots back on, and the cycle repeats, because the firmware file is still on the SD root.
Normally when you update your dashcam it should restart once the update is complete and delete the firmware file.
If that doesn't work, then I'm really out of ideas...
I don't think so.Does it matter that the DB-1 has two cameras?
