erkme73
- Jun 30, 2013
- a119v3 x 4
Turns out it's not the camera, but the GPS mount. There are four spring-loaded pins on the base. They're tiny, needle like protrusions that compress inward when the camera is slid onto the mount. When removed, the pins pop back up again.
Well, on the 9th unit (forward-facing camera for my RV) I was having real issues. Not only was the green GPS light not even blinking (stayed dark entirely), but when powering the camera through either of the two µUSB ports on the mount, the camera would power up just long enough to get to the live view, and the promptly shut down. The camera would stay powered and record just fine if the USB cable was plugged directly into the camera.
Upon closer inspection, with either young eyes, or a magnifying glass, you can see that one of the pins is staying in the retracted position. I tried to get it to pop back out (and buggered up the mount in the process), but no go. Gonna send an email to the seller to see what they recommend.
FWIW, when I put this camera in any of the other mounts, it worked 100% - so it's clearly the mount pins.
Just a heads up if your camera starts to get gremlins. We already know to suspect the battery and possibly faulty µSD card - but put this in your differential as well - defective pins...
![upload_2015-8-6_23-26-32.png upload_2015-8-6_23-26-32.png](https://dashcamtalk.com/forum/data/attachments/15/15576-c29f59efa090f6961e0c28ac10840220.jpg?hash=wp9Z76CQ9p)
