Joel Irwin
- Dec 30, 2015
I have had the 0806 since last Nov and aside for occasional 3 beep recording stop (I use Samsung 64 GB Pro +), I have had no problems or issues.... until about 3 or 4 weeks ago.
I use a standard USB cord wired around the top and into a 2 adapter lighter power connected in the bottom center in front of the seats. I put the Mini power USB cord in the higher rated amp connector (from memory I am thinking it is 2 amp). Normally, when I turn on the car the 0806 comes on immediately with the three start up tones. Then about 3 or 4 weeks ago, it did not come on immediately - it took maybe a couple of minutes and then it came on. I also found that if it didn't come on immediately, if I noticed, I would hit the on button on the left manually and it would come on.
Then earlier this week, it started to act up more - it would wait a couple of minutes to come on then after a while, it would turn off and come right back on again.
I decided to experiment and moved the power adapter from the base unit to the 0806 and SO FAR, everything is working fine - though the problem night come back.
I am thinking there is an issue with the base unit? What's your opinion? I am not the type of person who will open things up and fix things. I am also thinking that as I live here in SE Texas, that the problem could be heat related.
If it is the base unit and there is an option to purchase another one (just the base unit without the 0806), I may buy another one. Also as I received both the 0806 an 0805 for free last Nov (after a long battle with Gearbest which I discussed here months ago), it could be possible for me to use the base unit for the 0805 as a substitute - I assume it is compatible?
Comments?
Comments?
