DamnLookWhereYoureGoing
I'm quite uncomfortable with any dash cam holding recordings for a long time after I may need them. This would include where I've been, trivial inconsequential traffic violations, and conversations on the phone or with passengers. I only need the previous few minutes in case of an incident.
A feature to support this was something I looked at when choosing a camera. I found Garmin models have a "promptly delete" setting, which keeps only 3 minutes, however in case of an incident or manual save only 15 previous seconds are saved permanently. I was also generally not impressed with their products. I noticed the VS1 had a "loop recording" setting with options for 1-10 minutes, which seemed perfect, but it turns out this only controls the length of the individual video clips.
One suggestion on another forum many years ago was to use a small memory card, to cause frequent overwriting. Using the same idea, I've filled the 32GB that came with my VS1 with miscellaneous files (in a separate directory) so less than 2GB of space is free for recording. At maximum bitrate, this holds about only the most recent 10 minutes. One downside is that the same storage area of the card will be rewritten much more often, which I think will reduce card lifespan.
It would be great to have a feature to allow this without needing the user to use creative approaches. I've seen Viofo people read here, so please consider this suggestion.
