Operating temperature too high?
mrtori
Just got A119 from amazon, the framware is A119.160829.V1.1
I found that if I connet this cam to my computer through GPS unit, and after it runs about 10 minutes, the main screen part (I guess it is the inside of the device, since the SD card is hot as well) and the camera unit are getting a little bit hot, probably from 100 to 120 F (you can feel it is hot on your finger). While the outside is about 53 F (I guess it will be around 65 for inside).
I found that maybe it is because the manufacture film used to protect the screen and lens that block the heat so I removed them, and still it is a little bit hot, but do improved a lot. I can't image how this will work during the summer day my car just start from 1 hour exposed in the sun.
Since I am new to dash cam, I am not sure if it is normal for a dash cam. Also I am using the Lexar 633 128gb card, not sure if it is because of that(they said it only support up to 64gb, but some reviews said it can do with 128gb).
