Parking Mode
Gary Edstrom
Is there a configuration option that controls how much of a delay is required before the unit shifts into parking mode? I have a DR900X Plus/UHD-FHD that I have been using for around 2 years and everything has been running just fine. However, I recently noticed an issue with the camera not dropping into parking mode for an extended period of no motion. I normally saw it drop into parking mode 5-6 minutes after parking my car. However, this past week, I noticed several instances where it did not go into parking mode for more than an hour after parking.
There's no setting to change the motion-less delay time before it enters into parking mode. It's fixed at 5-minutes. The vehicle itself must be motion-less for that period of time, not that there's no motion within the field of view of the dash cameras. It should come out of parking mode when the vehicle's speed reaches 5 MPH/8 KPH. If you're relying on the motion status of the vehicle for parking mode, that means you must be powering it via the cigarette lighter adapter. The only other way to make it more predictable would be to use the 3-wire hardwire cable to power it.
Thank you for your response. It looks like I need to run a few more tests. I just thought about the fact that I use two 256GB chips and ping-pong between the two of them each week. I take the full chip and dump it to my computer were I maintain a 13-week record of all of my driving and parking video. I just noticed that one chip seems to be turning the camera microphone off while the other has it on. I need to check the config files between the two chips to see if there are any discrepancies. Yes, the system is plugged into my cigarette lighter via two BlackVue battery packs which can power the camera for about 30-36 hours. I never let the BlackVue battery run all the way down and supplement with A/C power via an adapter when necessary, so I have a true 24/7 uninterpreted view of my driving and parking. I live in a 24-unit condo building and my parking spot offers an excellent view of the garage so I run the camera 24/7 for a little extra security for the complex. There have been two times that there has been an unauthorized prowler in our locked garage checking all of the car doors to see if any were unlocked. I suppose if the camera is detecting MINOR vibrations where I am parked, that that may delay its dropping into parking mode. I need to review its sensitivity settings in both modes.
