Parking Mode
Have new a329s, gone from a Thinkware that is about ten or so , anyway seems that I can not for the life of me to get the parking mode to work? Have the HK6HARD WIRE kit, and keep telling myself it’s wired right, the Thinkware worked, it was wired to the same fuses,, new battery cutoff on 12.4 or something and moved it down to 11 something, is there something I’m missing , seems like everything is on that’s supposed to be , the cam. Works great but no parking mode
The first thing I would check is to make sure the HK6 hardwire 12V side wires are connected correctly. The wire colors for the VIOFO hardwire kits yellow/red are reversed of the Thinkware wires yellow/red. The VIOFO HK6 red wire is connected to VCC+/BAT/constant power. The VIOFO HK6 yellow wire is connected to ACC [accessory/switched] power.
Yes thanks, have the red on 12v power , yellow on 12v after start, but have tried them both ways , also have outside fuse clip on incoming power,
I believe that’s the right way? I switched the wires around thought it could have been marked wrong?
What parking mode settings do you have configured for the A329S?
  • Video Settings > Parking Recording
    • Vehicle Battery Protection
      • Cut-Off Time
      • Cut-Off Voltage
    • Parking Mode
      • Off
      • Hybrid Parking Recording
        • Low Bitrate -> Impact
        • Event Detection -> Impact
        • Time-lapse 1 fps (SNV) -> Impact
        • Time-lapse 1fps -> Impact
        • Time-lapse 2fps -> Impact
        • Time-lapse 3fps -> Impact
        • Time-lapse 5fps -> Impact
        • Time-lapse 10fps -> Impact
      • Low Power Impact Detection
      • Low Bitrate Recording
      • Auto Event Detection
      • Timelapse 1 fps (Night Vision)
      • Timelapse 1 fps
      • Timelapse 2 fps
      • Timelapse 3 fps
      • Timelapse 5 fps
      • Timelapse 10 fps
    • Enter Parking Mode Timer
      • Off
      • 90 seconds
    • Parking Files Storage
      • MicroSD Card
      • SSD
    • GeoFencing
      • Zone 1
      • Zone 2
      • Zone 3
There are a few other parking mode related settings, but they shouldn't govern if the A329S enters parking mode. If you have GeoFencing enabled for any of the the three zones and your vehicle is located at that location, the dash camera would turn off rather than going into parking mode when you turn off your vehicle's ignition switch.
If you're using the same VCC+/BAT+ power source as you did for your other dash camera, you should have a good constant power supply while parked. You might want to confirm that the VCC+/BAT+ circuit is staying powered and only the ACC+ circuit is turning off when the ignition switch is turned off.
      • Cut-Off Time 1 hrs
      • Cut-Off Voltage 12.4. Tried most
    • Parking Mode
      • Off on
        • Low Bitrate -> Impact 👍
        • Time-lapse 2fps -> Impact. Tried most all of them
      • Low Bitrate Recording👍
      • Timelapse 1 fps (Night Vision)👍
      • Timelapse 1 fps
      • Timelapse 2 fps.
      • Timelapse 3 fps
      • Timelapse 5 fps
      • Timelapse 10 fps
      • Off👍
      • 90 seconds-
      • MicroSD Card👍
      • SSD
    • GeoFencing. Have not even looked at this ? Tomorrow
      • Zone 1
      • Zone 2
      • Zone 3
Yes thanks much, have tried the power many different ways, cameras work most ways but sill no. Parking mode
Sounds like you got it figured out.
If not, remove camera from car & test indoors.
Perform factory reset / default settings.
Start watching video at 2:18
Thanks will try tomorrow, have a drs appointment early, but after, it’s on again, maybe try factory reset to start with? And then unglue from window again 🤢and test inside
Came home and just reset everything to factory, then setup again, seems to be working right now, will see later if I have to redo anything
