I found that it did help a bit in my testing, contrast-wise it added some depth and clarityDo you use the PlatePix feature on your N4 Pro? I've noticed it tends to make the image darker.
Hi Milamber,Do you use the PlatePix feature on your N4 Pro? I've noticed it tends to make the image darker.
I had HDR on/off and CPL on when I submitted my footage which is on one of Vantrue's Instagram posts. Performed decentlyDoes anyone know/tested so far if or how HDR and the use of a polarising filter affects PlatePix performance?
I’m also wondering about this since I use the CPL filter and find the image quite dark in bright sunlight. I’m unsure whether this is due to the CPL filter or the PlatePix feature.Does anyone know/tested so far if or how HDR and the use of a polarising filter affects PlatePix performance?
PlatePix does darken the image.I’m also wondering about this since I use the CPL filter and find the image quite dark in bright sunlight. I’m unsure whether this is due to the CPL filter or the PlatePix feature.
I haven't seen or read any official information on how it works. But when taking a look at the wheels of the oncoming cars, it does appear to have a faster shutter speed.Does PP basically crank up the shutter speed and mildly crank up the ISO as needed to compensate, but still trend on the side of slight underexposure? Are you all seeing instances where HDR on and PP off yields better results?
