hlk
Hi ALL, trying my luck here.. . Anyone has blackvue Dashcam installed on a lexus hybrid using power magic pro? Seems like mine doesn't work and don't know why. My car is 2016 lexus RX hybrid
Yellow wire has been wired to hazard fuse and red wire has been wired to power socket fuse using fuse tap. The camera can be turned when the car is on but when engine is off the camera shut itself, same goes to power magic pro green led. The pmp won't turn itself on when car restart and need manually turn off and on again.
I checked the battery the voltage level can sometimes drop to 11.6V when car is off, is this normal? I have technician to check my car battery as well and was told it was still in good condition, 14V when engine is on.
I suspect could it be the battery used by the hybrid won't regulate itself anymore or a faulty PMP?
Thanks in advance.
Thanks in advance.
