Rifleman
- Feb 16, 2016
- Nottingham
- United Kingdom
- mini0806, mini0801,Viofo A119
I have posted comments about poor performance of the A119 GPS unit in another topic. I was hoping for a reply from Viofo but sadly they have ignored the issue so far 🙁.
Is anyone else having GPS issues ?
If it might be a GPS receiver problem and not something that can be fixed in firmware I need to know very soon so that I can return the A119 for a refund as in my opinion the GPS receiver is not fit for purpose.
Here's my original fault report:-
"The GPS logger is very unstable, quick to get first fix but far too many drop outs while driving. For instance on one 30min journey the GPS data was only visible on the recorded footage for approx. 15 mins with multiple gaps. The track shown in Dashcam viewer is wildly erratic, in the same journey the track only matched with the actual route taken for about 2 minutes, rest of the time is was offset by anything up to 200-300m when working, just straight lines between two points in places because of drop out.
I compared this with footage from the rear view mini801 with GPS ( the A119 replaced this, it was front camera but moved it to rear ) over the same period. The mini801 GPS was much slower to get initial lock BUT once locked it stayed locked throughout the journey. Viewing footage from this in Registrator Viewer showed the GPS data to be rock solid, matched up perfectly with the actual route to with just a few meters.
Can something be done in the firmware to correct this very poor GPS performance or is it more likely to be the GPS receiver that's at fault ?"
By the way, I've swapped the A119 with the mini801. 801 is now returned to the front windscreen with GPS working fine. A119 is now mounted on back ( vertical ) window on non-GPS mount. This mount is a much looser fit than the GPS mount and I'm experiencing a fair bit of vibration between the camera and the mount. I am looking at ways of stopping this movement with wedges, sticky pads etc. , has anyone else experienced this ?
