Power cable question
Lynn1953
North Alabama
I’m thinking of powering my 229plus using a dongar mirror tap. My question is will a generic usb to usb-c work-? I did a query on here but no luck. I would assume it would. Just thought someone may have tried this.
As long as it is a power cable rather than a data cable, and it is USB-A to USB-C, then you should be fine. Long cables can cause problems, but obviously yours will be short. USB-C to USB-C will cause problems with many USB power sources, you need to convert it to USB-A before using it!
The dongar et al show a standard usb female to plug into.
I'm pretty sure that you will be fine.
If you are using 3 video channels, then I recommend using Viofo's hardwire kit, but I still think it will be fine.
Check this link for reference
