If the Mini 2 is on and shooting, then there is of course power consumption, regardless of whether the parking mode is on or not.Hello,
I would like if anyone could clarify the following:
Thanks.
- Is there any power consumption when the camera parking mode is OFF (in settings)?
- If there is, how big is this power consuption?
Thank you for your answer, however, I can see now that I did not specify the question correctly.If the Mini 2 is on and shooting, then there is of course power consumption, regardless of whether the parking mode is on or not.
If the Mini 2 is off, then there is no power consumption, regardless of whether the parking mode is on or not.
Once again you have formulated the question incorrectly.Thank you for your answer, however, I can see now that I did not specify the question correctly.
My questions are only for the situation, when the car engine is off AND the camera parking mode is off.
In other words, when the car engine is off and the camera pakring mode is off, will the camera power off itself?
Thanks, Mini 2 gets its power from the HK4 hardwire kitOnce again you have formulated the question incorrectly.
You have not indicated where the Mini 2 gets its power from.
HK4 hardwire kit does consume voltage, but very little.Thanks, Mini 2 gets its power from the HK4 hardwire kit
Ok, so should I understand this in the way that when the car engine is off and the camera pakring mode is off while the camera is connected through the HK4 hardwire kit the camera itself will be off and there will be only very little voltage consumption on the HK4?HK4 hardwire kit does consume voltage, but very little.
Certainly.Ok, so should I understand this in the way that when the car engine is off and the camera pakring mode is off while the camera is connected through the HK4 hardwire kit the camera itself will be off and there will be only very little voltage consumption on the HK4?
It is going to use approximately 0.01 Watts, an insignificant amount if your car is driven weekly.Ok, so should I understand this in the way that when the car engine is off and the camera pakring mode is off while the camera is connected through the HK4 hardwire kit the camera itself will be off and there will be only very little voltage consumption on the HK4?
