I searched for a solution for this same issue, and didnt find an easy to use alternative yet. Especially for electricity n00b like myself
At one point I was thinking about adding another car battery to the engine bay, and plug it into a second alternator. This extra battery will be used for all added accessories I have
Not sure if it is a good idea though. Is it?!
Fitting a second alternator is likely to be a nightmare! Much easier to fit a more powerful alternator.
If you drive > 4 hours a day on average then you should be fine with a standard lead acid battery and cut-off at 12.2 volts.
If you drive 2 - 4 hours a day on average then you should be fine with a long life, maintenance free, calcium battery and cut-off at 12.0 volts.
If you drive 1 - 2 hours a day on average then you should be OK with an AGM battery and cut-off at 11.8 volts, maybe get a larger AGM battery for closer to 1 hour if it will fit.
If you drive 45 minutes to 60 minutes a day on average then a Cellink Neo or similar is the answer but rather expensive.
For less than 40 minutes a day you will need to bring external power unless you have both an upgraded alternator and very large lithium battery.
A 20,000mAh USB powerbank will keep a dual dashcam running for 24 hours. With a standard one you can charge it in the house overnight, preferably somewhere where a fire is not a big problem, or if you follow the rule that charging powerbanks should always be supervised due to the risk of fire then get a quick-charge one that can charged at 45 watts and be full in around 2 hours. If you want it running the dashcam while charging then you need two and alternate them. Using a powerbank charged in the house solves the problem that lithium batteries should never be charged below freezing.
If using a lead acid battery of any type then you should ensure that it occasionally gets charged to 100.00% full, preferably once per month, either by a long drive (> 6 hours) or using a battery charger.
It is often easier to fit a larger car battery than to fit an additional battery, and one larger battery that rarely gets emptied is better than one standard car battery that rarely gets emptied plus a smaller additional battery that regularly gets very empty and thus doesn't live long. Many gasoline powered cars have space or an alternative battery mount available to fit a larger battery intended for diesel engines.
Larger batteries will charge faster, although it may take longer for them to reach 100% full, lithium batteries are happier if they never reach 100% so a large lithium battery doesn't need filling and will have a longer lifetime so is likely a good investment.
