camdashuser
- Feb 10, 2018
Well, I plugged it in to the car and I can't get any response when I hit menu. Looks like this is a dud unit.
It's a Viofo A118c2what brand is it? there are clones of this cam
When it powers on there is no red record light on the screen or the backlight on the housing. I don't understand it since if it isn't recording I should be able to get into menu.you have to press the REC key to stop it recording before you can get into the menu
don't ever remove or insert cards while the camera is powered on, you can damage the card
what card are you using?
Loop timer should always be left on, don't turn it off
Maybe go into the menu and reset default settings and start again
If you turn loop off it won't work correctly as a dashcam
