Hi,
I have a bit of a problem with my Mobius cam.
I am using it as a dash cam and it worked for a while. However, things have gone awry over the past few weeks.
The problem is that the cam doesn't record reliably. Most of the files on the card are 1 second long, there are a few 14 second long files and very, very rarely do I get full 3min video. Much of the time camera doesn't record at all.
I've noticed that instead of flashing yellow on the back of the cam, I'm seeing alternating flashes of yellow in the back and blue at the face of the camera. Couldn't find any explanation what this may mean.
My settings file is below. I've updated the firmware and tried several config tweaks without any luck. Any help appreciated.
Code:
Date time=[2013/12/19-14:31:16];date time setting,format yyyy/mm/dd hh:mm:ss
Video Mode 1 resolution=[0];Movie resolution setting,0:1080p(Large AOV),1:1080p(Small AOV),2:720p(Large AOV),3:720p(Small AOV)
Video Mode 1 Frame Rate=[2];Movie frame rate setting,1:60fps (only for 720p small AOV), 2:30fps
Video Mode 2 resolution=[2];Movie resolution setting,0:1080p(Large AOV),1:1080p(Small AOV),2:720p(Large AOV),3:720p(Small AOV)
Video Mode 2 Frame Rate=[2];Movie frame rate setting,1:60fps (only for 720p small AOV), 2:30fps
Photo Mode Capture Size=[1];set photo size,0:2304x1536,1:1920x1080,2:1280x720
Set Time Lapse Shooting=[0],0:off,1:0.25s,2:0.5s,3:1s,4:2s,5:5s,6:10s,7:30s,8:60s
Photo Flip=[1];set Photo rotate,0:off,1:flip on
Movie cycle time=[0];movie cycle time,0:3 minutes,1:5 minutes,2:10 minutes,3:15 minutes,4:max to 4G byte,
Movie Loop Recording=[1];set loop recording on or off,0:off,1:on,
Time stamp=[1];set date/time stamp on or off,0:off,1:on,
Movie sound=[0];set movie sound,0:mute,1:on,
Movie Flip=[3];set movie rotate,0:both off,1:mode 1 on and mode 2 off,2:mode 1 off and mode 2 on,3:both on,
Movie quality=[0];set movie quality,set movie data rate,0:Super,1:Standard,2:Low,
Movie high dynamic range=[1];set movie high dynamic range,0:off,1:on,
Power on=[1];set system power on time,0:delay,1:fast
Power off=[0];set system auto power off time when system pending,0:off,1:30 seconds,2:1 minutes,3:2 minutes,
Auto Record with External Power=[1];set connect with power to start video recording automatically,0:off,1:on,
One Power Button to Auto Record=[1];set press power key to start video recording automatically,0:off,1:on,
Auto Off with External Power disconnected=[1],0:Immediately,1:delay 10s;2:record to low battery power off,
LED=[1];set LED flicker when recording,0:off,1:on,
Charge from USB Host=[1]; when connecting with USB host, charge camera or not,0:on,1:off
Lens option =[0];select lens,0:lens A,1:lens B
Light frequency =[0];set light source frequency,0:50 HZ,1:60 HZ
TV out=[1];set Tv out,0:NTSC,1:PAL,
TV Display Ratio=[1];set display ratio,0:4*3,1:16*9
{TLCAM MOV:TLCAM Mobius ActionCam 2013/11/22 v0.59}
{LDTLCAM,v003}
