zander21510
- Feb 5, 2014
Hi,
I bought this on Amazon, and I've only been able to get it to power on a couple of times, when I first got it I was able to push the power button and it turned on just fine, but then it shut off when it ran out of battery power (like 30 seconds). I plugged it into the wall and I couldn't get it to turn back on. I let it charge till the red light went out and still it would not turn on. I opened it up to see if something was loose, while putting it back together it randomly powered on before I even put the LCD screen and Camera back on. I was able to shut it off with the power button so I could continue putting it back together. But when it was back together, it wouldn't turn on. I did it again, and once again it turned on randomly, I'm not sure I don't think I even pushed the power button. This time I was able to go through the menus and test things and record video and everything worked just fine with it plugged in. It was a bit odd, many settings didn't match the manual and the firmware version was just a string of numbers starting with 2013....so finally I had to turn it off...which I did. And now, I can't get it to turn back on no matter what I do. Any ideas?? Also, here are some pictures of the board inside...
![2mwy147.jpg](/forum/proxy.php?image=http%3A%2F%2Fi61.tinypic.com%2F2mwy147.jpg&hash=6c3d43127f0825c5b06bb9ce9ff6f616)
![b6aeci.jpg](/forum/proxy.php?image=http%3A%2F%2Fi59.tinypic.com%2Fb6aeci.jpg&hash=55bdd1ce5f543e3c34be7a3910c53b4b)
