Gaspar
- Oct 12, 2015
- Argentina
- Transcend Drive Pro 200
Where I park my car there are no fixed spots so other people that park their cars there some times have to move mine. I have a car that has push button ignition. If you push the button once, with out pushing the brake or clutch pedal, only the electronics turns on. It is the on position. But if you push the brake or clutch pedal the car will start. The camera starts recording when the door of the car is opened. The problem is that if the car is started directly with out putting it in the on position first, the file that the camera recorded is saved but it can not be seen. Is corrupted. That does not happen if you put the car ignition in the on position before you start the car. ¿There is a problem with my camera o this is a normal thing? Because I used to have a Transcend 200 and never had this problem.
