coffeefiendlol
- Sep 5, 2014
Hello all, I'm planning on hardwiring my new dashcam so that parking mode is an active feature.
BUT, I have some questions as to how I can disable that feature downstream if it turns out that it's using up my car's battery and causing poor starts. This has happened to my friend so I am a bit concerned.
Once the car is properly hardwired, is it possible to without having to rewire anything disable the parking function for the dashcam via its built in software/app so that the power does not drain anything from the battery (i.e. parking mode feature is turned off)? Or, does that not matter and simply having the hardwire kit plugged into an always-on fuse mean that it will continue to drain power?
Also, what if we just simply disconnect the dashcam from the power cable when the car is parked? I know the hardwire cables would still be connected to whatever fuse allows for the parking monitoring to function, but since there is nothing plugged in to the end cable, would it still drain the car's battery?
Is there a preference to select a cut off between 12v and 11.6v? I'm thinking 12v so it keeps the battery slightly higher charged.
Is there also a preference on the best fuse to tap when installing hardwired dashcams if the preference is to not impact any critical pieces of hardware? Right now, with my old dash cam, I believe it's tapped into the ignition so it only comes on when the car is turned on (at least acc mode) but otherwise there is no power going into the dashcam (with no parking function on the old dash cam).
