Edward M. Grant
- Jun 2, 2015
- Saskatchewan
- Canada
- A118C, SG9665GC
On the wishlist thread, we had a brief discussion about my problem with random 'card error' messages when the camera starts up. If I turn the car off and on again, the error goes away, so it doesn't seem like a real problem with the card, though I have once seen a corrupt recording.
I thought I'd split that to a separate thread, to update as I investigate it, and not clog up that thread with off-topic posts.
Two theories were proposed:
1. It's a bad card.
2. The camera doesn't like Sandisk cards.
I've got a second camera in the back now, so I swapped the cards over. Both are 64GB Sandisk Ultra class 10, formatted in the camera. That card was fine for a few days, but yesterday I had a 'card error' again. So that seems to eliminate #1.
One thing I did notice is that, when I started the engine that time, the power light on the camera went out for a second or two and came back. I also noticed that the front camera did its bootup tones a few seconds after the rear camera, so it clearly took longer to boot up. It's possible this may be caused by a brief power glitch, but I'll need more occurrences before I can prove that.
I have a nondescript 8GB card here that came with the camera, so I'll try installing that at some point soon and see if it has any card errors. I'll probably also swap over the front and rear cameras to see if it's the camera, not the card.
1. It's a bad card.
