Rear camera installation
JeffIan
Lakewood
I would like to install rear camera on 2017 Camry. Would it be better to install via passenger's side or driver side? Is it better to install above the doors or run along below the doors? Any advice would be appreciated.
Thanks.
If you install the front camera on the passenger side, run the cable on that side.
I always recommend running the cable below the doors to not interfere with the side curtain airbags! (if you have any)
I'm not quite sure I understand. It is precisely because of the airbags that I thought it would be better to install above the doors. That would avoid having to deal with both the A pillar and the rear pillar, both of which have airbags
I don't have Camry service manual but the A pillar and rear pillar airbags are probably single, continuous air curtain. That is the case in most vehicles (and if ebay parts listing are to be believed this is true also for 2017 Camry). There is much higher chance of interference with that air curtain by running the wire above doors unless you are willing to take time and care to make sure you are running the cable above the curtain and that usually requires removal of the middle pillar trim. And that, depending on the vehicle, can get complicated (in case of my Leaf properly removing the upper center pillar trim requires removing both front and rear door kickplates, lower center pillar trim and partially removing the seatbelt) .
After I replied I realized I was incorrect, and it is in fact like you say. So I will need to go below the doors. Do you have any advice about how to fish the dash cam cable from the trim in the rear door to the rear window?
I usually use a thick (13AWG/2,5mm2 or thicker) solid core copper wire (with insulation on) and I loop the ends so there is absolutely no sharp edges exposed. It can be had in long sections for cheap, holds its shape so can be bent to navigate better behind panels.
For the love of god make sure your wire is long enough for what ever route you choose to run.
I have often run wires high, just in front of curtain airbag, it do not worry me much that the wire might get damages or dislodged in a accident, everything should deploy strait down none the less.
The point is not the damage to the wire but the wire embedding in the heads and faces of passengers when the air curtain deploys or preventing it from deploying correctly. It does not matter if it's unlikely, you don't **** with safety systems.
When I was installing my rear channel I sat down with the service manual and dissembled significant portion of the trim to run the cable safely. It took me 1,5hours including wrapping it in sound absorbing foam tape so it does not rattle and snaking it through factory grommets to the rear hatch. 1.5hours is a low price for doing it correctly.
Indeed but many like to jump the fence where it is the lowest.
I am not worried much CUZ i am the only one in my car, i think now the +12 years i have owned it i had other people ( 1 or more ) in it for a total of 3 hours tops.
I am absolutely fine with any stupidity or laziness of mine hurting myself.
This is the right and the only way to properly install cables.
Don't interfere with safety features in any way.
That is probably one of the best videos I have seen on installing wire, thanks for posting it. It is old news for me, but still a good video for other to see.
Thanks.
If possible, install opposite of the radio/satellite cable that goes from the radio to the back of the car...where usually the radio and satellite antennas are found. This avoids any EMF/RF interference between your camera cable and other antenna cables. It may not make a difference for your card and may not matter at all, but only a suggestion. Just got to make sure you have a cable that is long enough. 🙂
I think I prefer to be safe. But the question becomes how best to handle threading through the C pillar. I saw Chris Fixx video that was posted here. In my Camry it seems to be pretty tight with a lot of obstacles in the way. I am not sure fishing the cable through would work. Has anyone tried to remove the C pillar?
My last Camry was a 1996 so I do not remember the C-pillar arrangement but, all you really want to do is get the wire/cable tucked beneath the headliner back there and ran a few feet over to the top center of the back window. I believe the 2017 rear airbag is along the seat side and not the top so, if you run the cable along the top headliner, but behind the SRS bags, you should be OK. Usually at the B-pillar there is plenty of space to pull the cable through or to push it through.
I would recommend tracking down a service manual. Usually people share those on user forums for a manufacturer or specific model or they can be purchased for like $20 on ebay.
In case of my car removing the C pillar trim required disassembling the entire trunk but it could be unclipped enough to see what is behind it and safely maneuver the wire behind it. I would start from partially removing the door rubber welt (in 9 out of 10 vehicles is just slid over the door frame weld so you just can pull on it and it comes right off, you push it back to reinstall). This usually creates enough of a gap to look behind the trim and locate the clips or even snake the wire without unclipping anything. Just don't force anything if you are unsure.
I did like you suggested and was able to see a little behind the C pillar. What I noticed is that the air bag partially lies in that area. I also noticed that the plastic pillar piece has more than a few ridges jutting out. My concern is obviously to avoid the air bag and at the same time to not damage the dash cam cable. That's why I thought it's a good idea to take off the pillar in order to direct the cable more carefully.
